hi
i am not able to associate this CT101 thermostat - keeping getting the following error message. Any help would be greatly appreciated. It shows it has been successfully added but no node file is created- also in the end it states the node failed to initialize.
INFO 2017-07-13 23:17:06,341 : Inclusion_Manager : Node ‘33’: Z-Wave node has been successfully added to the Z-Wave network.
INFO 2017-07-13 23:17:06,351 : Controller : Z-Wave
node info (ID=33) : [[Device Classes :‘BASIC_TYPE_ROUTING_SLAVE’,’
GENERIC_TYPE_THERMOSTAT’,‘SPECIFIC_TYPE_THERMOSTAT_GENERAL_V2’],[Capabilities: ‘NODEINFO_CAPABILITY_ROUTING’],[Security :‘NODEINFO_SECURITY_FLIRS_WAKEUP_1000’,‘NODEINFO_SECURITY_OPTIONAL_FUNC_SUPPORT’]].
WARN 2017-07-13 23:17:10,021 : Node : Node ‘33’: Discarded [APP_CMD_HANDLER_FRAME : NodeID=‘33’,
Status=[RECEIVE_STATUS_TYPE_SINGLE],CommandClass=‘COMMAND_CLASS_NO_OPERATION’, Command=‘0x31’, Parameters:[0x05, 0x05, 0x01, 0x44]] because endpoint ‘2’ is out of valid range[1].
WARN 2017-07-13 23:17:10,023 : Node : Node ‘33’: Discarded [APP_CMD_HANDLER_FRAME : NodeID=‘33’,
CommandClass=‘COMMAND_CLASS_NO_OPERATION’, Command=‘0x31’, Parameters:[0x05, 0x05, 0x01, 0x44]] because ‘COMMAND_CLASS_NO_OPERATION’ hasnt been implemented yet or the node hasnt been initialized yet.
ERROR 2017-07-13 23:17:14,972 : Node_Initializer : Node’33:2’ : [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET
(Retry=‘1’)] failed : ‘COMMAND_CLASS_REPORT_TIMEOUT_ERROR’
ERROR [pool-2-thread-1219]: Node_Initializer : Node ‘33:2’: [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET (Retry=‘1’)]
WARN 2017-07-13 23:17:16,424 : Node : Node ‘33’: Discarded [APP_CMD_HANDLER_FRAME : NodeID=‘33’,
[1].
WARN 2017-07-13 23:17:16,425 : Node : Node ‘33’
ERROR 2017-07-13 23:17:21,240 : Node_Initializer : Node
‘33:2’ : [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET
(Retry=‘2’)] failed : ‘COMMAND_CLASS_REPORT_TIMEOUT_ERROR’
ERROR [pool-2-thread-1218]: Node_Initializer : Node ‘33:2’
: [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET (Retry=‘2’)]
WARN 2017-07-13 23:17:22,662 : Node : Node ‘33’
[0x05, 0x05, 0x01, 0x46]] because endpoint ‘2’ is out of valid range
[1].
WARN 2017-07-13 23:17:22,664 : Node : Node ‘33’
[0x05, 0x05, 0x01, 0x46]] because ‘COMMAND_CLASS_NO_OPERATION’ hasnt
ERROR 2017-07-13 23:17:27,492 : Node_Initializer : Node
(Retry=‘3’)] failed : ‘COMMAND_CLASS_REPORT_TIMEOUT_ERROR’
: [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET (Retry=‘3’)]
WARN 2017-07-13 23:17:28,851 : Node : Node ‘33’
[1].
WARN 2017-07-13 23:17:28,852 : Node : Node ‘33’
ERROR 2017-07-13 23:17:33,788 : Node_Initializer : Node
(Retry=‘4’)] failed : ‘COMMAND_CLASS_REPORT_TIMEOUT_ERROR’
: [COMMAND_CLASS_SENSOR_MULTILEVEL::SENSOR_MULTILEVEL_GET (Retry=‘4’)]
ERROR 2017-07-13 23:17:33,790 : Node : Node33’ : Failed to initialize node.
ERROR [pool-2-thread-1217]: Node : Node ‘33’ :Failed to initialize node.
