Hi Rainer,
i just noticed that the temperature does not auto update with the command AIR_TEMPERATURE_SCALE_FAHRENHEIT and its associated sensor.
I have a button tied to this command as well and when i press it it does update the sensor value.
do i have to set up a rule to poll it every so often is it supposed to send updates when the actual tempertaure changes. I do see it change in the LCD panel on the thermostat istself, just not on the Openremote app? this is for CT101.
