I tried excluding the node and including it without security. I have attached all the log entries below. It appears that it is using COMMAND_CLASS_ALARM::ALARM_REPORT with ‘EVENT_DOOR_WINDOW_OPEN’ and ‘EVENT_DOOR_WINDOW_CLOSE’
I am guessing it is using ALARM_TYPE_ACCESS_CONTROL
is this supported in zwave 3.3.0 version of openremote? if yes what command should i use in openramote?
Currently i am using “status” when building command in the designer
node file shows:
ALARM_TYPE_HOME_SECURITY
i also looked at the manual and it states the following:
Parameter 14 Enable/Disable BASIC SET Command
The sensor can send the BASIC SET command to nodes associated with group 2.
0 = Disable
1 = Enable
Parameter Size: 1 byte
Default Setting: 0
Parameter 15 Value of the BASIC SET
The BASIC SET value sent by the sensor when the magnet is triggered can be reversed
from its default state.
0 = Sends the BASIC SET VALUE 255 to nodes associated with group 2 when the
door/window is opened and sends the BASIC SET VALUE 0 to nodes associated
with group 2 when the door/window is closed.
1 = Sends the BASIC SET VALUE 0 to nodes associated with group 2 when the
door/window is opened and sends the BASIC SET VALUE 255 to nodes
associated with group 2 when the door/window is closed.
Default Setting: 0
if i want to use the basic set, how do i change the parameter 14 from 0 to 1?
DEBUG 2019-10-18
19:46:14,337 (Z-Wave): RX_Session_Layer : Node ‘54’ :
[APP_CMD_HANDLER_FRAME : NodeID=‘54’, Status=[RECEIVE_STATUS_TYPE_SINGLE],
CommandClass=‘COMMAND_CLASS_ALARM’, Command=‘0x05’, Parameters: [0x00, 0x00,
0x00, 0xFF, 0x06, 0x16, 0x00, 0x00]]
DEBUG 2019-10-18 19:46:14,338 (Z-Wave):
CCAlarmV2 : Node
‘54:0’ : [COMMAND_CLASS_ALARM::ALARM_REPORT, AlarmTypeV1=[Dec:‘0’
Hex:‘0x00’], AlarmLevelV1=[Dec:‘0’ Hex:‘0x00’], AlarmStatus=‘UNSOLICITED_ALARMS_ENABLED’,
AlarmType=[‘ALARM_TYPE_ACCESS_CONTROL’, Dec:‘6’, Hex:‘0x06’],
EventType=[‘EVENT_DOOR_WINDOW_OPEN’, Dec:‘22’, Hex: ‘0x16’]].
DEBUG 2019-10-18 19:46:15,239 (Z-Wave):
: [APP_CMD_HANDLER_FRAME : NodeID=‘54’, Status=[RECEIVE_STATUS_TYPE_SINGLE],
CommandClass=‘COMMAND_CLASS_BATTERY’, Command=‘0x03’, Parameters: [0x64]]
CCBattery : Node
‘54:0’ : [COMMAND_CLASS_BATTERY::BATTERY_REPORT, BatteryLevel=‘100’].
DEBUG 2019-10-18 19:46:19,189 (Z-Wave):
0x00, 0xFF, 0x06, 0x17, 0x00, 0x00]]
DEBUG 2019-10-18 19:46:19,190 (Z-Wave):
CCAlarmV2 : Node
EventType=[‘EVENT_DOOR_WINDOW_CLOSE’, Dec:‘23’, Hex: ‘0x17’]].
DEBUG 2019-10-18 19:46:20,061 (Z-Wave):
DEBUG 2019-10-18 19:46:20,062 (Z-Wave):
CCBattery : Node
