Ubuntu 14.04 box (running OpenRemote 2.6.0 B3).
I am having an issue adding the Aeon Labs Smart Dimmer 6 to my environment. It appears i can send on off commands, but dim and status commands are not sent (command builder completes, but no TX)
Here is the associated device xml:
openremote/webapps/controller/zwave/node24.xml
<?xml version="1.0" encoding="UTF-8"?> AEON Labs BASIC_TYPE_ROUTING_SLAVE GENERIC_TYPE_SWITCH_MULTILEVEL SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL true true ELECTRIC_METER ELECTRIC_METER_SCALE_KWH ELECTRIC_METER_SCALE_W ELECTRIC_METER_SCALE_A ELECTRIC_METER_SCALE_V true COLOR_CHANNEL_RED COLOR_CHANNEL_GREEN COLOR_CHANNEL_BLUE GENERIC_TYPE_SWITCH_MULTILEVEL SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL UNKNOWN UNKNOWN GENERIC_TYPE_SWITCH_MULTILEVEL SPECIFIC_TYPE_POWER_SWITCH_MULTILEVEL COLOR_CHANNEL_RED COLOR_CHANNEL_GREEN COLOR_CHANNEL_BLUE``
And here is the zwave.log output when I send an ‘on’ command. Everything seems to work fine.
DEBUG 2018-11-26 21:42:00,612 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2018-11-26 21:42:00,613 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘24’, endPoint = ‘1’
DEBUG 2018-11-26 21:42:00,614 (Z-Wave): Command_Builder : Z-Wave command: command = ON
DEBUG 2018-11-26 21:42:00,614 (Z-Wave): Command_Builder : Z-Wave command: paramValue = null
DEBUG 2018-11-26 21:42:00,614 (Z-Wave): Command_Builder : Z-Wave command created successfully
DEBUG 2018-11-26 21:42:00,615 (Z-Wave): CCMultiLevelSwitch : Node ‘24:1’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’]
DEBUG 2018-11-26 21:42:00,618 (Z-Wave): Controller_API : Enqueue (queue count=1) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1c531b4’.
DEBUG 2018-11-26 21:42:00,618 (Z-Wave): Controller_API : Dequeue (queue count=0) Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1c531b4’.
DEBUG 2018-11-26 21:42:00,619 (Z-Wave): TX_Session_Layer : Executing Z-Wave function call ‘org.openremote.protocol.zwave.model.commandclasses.CCMultiChannelV2FuncDecorator@1c531b4’…
DEBUG 2018-11-26 21:42:00,622 (Z-Wave): TX_Session_Layer : Send (repeat count=1) Z-Wave function ‘ZW_SendData(NodeID=24, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x02)’ request (callback ID=0x02).
DEBUG 2018-11-26 21:42:00,625 (Z-Wave): TX_Frame_Layer : Send data frame [0x01, 0x0E, 0x00, 0x13, 0x18, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x26, 0x01, 0xFF, 0x05, 0x02, 0x4E].
DEBUG 2018-11-26 21:42:00,645 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x06]
DEBUG 2018-11-26 21:42:00,648 (Z-Wave): RX_Frame_Layer : ACK -> Data frame [0x01, 0x0E, 0x00, 0x13, 0x18, 0x07, 0x60, 0x0D, 0x00, 0x01, 0x26, 0x01, 0xFF, 0x05, 0x02, 0x4E] transmission OK.
DEBUG 2018-11-26 21:42:00,649 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2018-11-26 21:42:00,649 (Z-Wave): RX_Session_Layer : ACK -> Z-Wave function ‘ZW_SendData(NodeID=24, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x02)’ has been successfully sent - waiting 5,000 [ms] for response frame.
DEBUG 2018-11-26 21:42:00,651 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x04, 0x01, 0x13, 0x01, 0xE8]
DEBUG 2018-11-26 21:42:00,652 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] has been received.
DEBUG 2018-11-26 21:42:00,654 (Z-Wave): RX_Session_Layer : ‘ZW_SendData’ response [0x01, 0x04, 0x01, 0x13, 0x01, 0xE8] with status ‘RETURN_VALUE_TRUE’ received (callback ID=0x02).
DEBUG 2018-11-26 21:42:00,655 (Z-Wave): RX_Session_Layer : Waiting 64,966 [ms] for ‘ZW_SendData’ callback frame (callback ID=0x02).
DEBUG 2018-11-26 21:42:00,689 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x01]
DEBUG 2018-11-26 21:42:00,691 (Z-Wave): RX_Serial_Port_RXTX : Data bytes read : [0x05, 0x00, 0x13, 0x02, 0x00, 0xEB]
DEBUG 2018-11-26 21:42:00,693 (Z-Wave): RX_Frame_Layer : Data frame [0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xEB] has been received.
DEBUG 2018-11-26 21:42:00,695 (Z-Wave): RX_Session_Layer : Callback [0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xEB] (callback ID=0x02) with state ‘TRANSMIT_COMPLETE_OK’ received -> Z-Wave function ‘ZW_SendData(NodeID=24, Payload=[0x26, 0x01, 0xFF], TxOptions=[TRANSMIT_OPTION_AUTO_ROUTE, TRANSMIT_EXPLORE_OPTION_ACK], CallbackID=0x02)’ successfully executed.
DEBUG 2018-11-26 21:42:00,697 (Z-Wave): CCMultiLevelSwitch : Node ‘24:1’ : [COMMAND_CLASS_SWITCH_MULTILEVEL::SWITCH_MULTILEVEL_SET, Value=‘255’] succeeded
Unfortunately, this is all I get when I send the ‘dim’ command (command does not appear to be case sensitive, tried both)
DEBUG 2018-11-26 21:43:41,534 (Z-Wave): Command_Builder : Building Z-Wave command
DEBUG 2018-11-26 21:43:41,535 (Z-Wave): Command_Builder : Z-Wave command: nodeId = ‘24’, endPoint = ‘1’
DEBUG 2018-11-26 21:43:41,535 (Z-Wave): Command_Builder : Z-Wave command: command = DIM
DEBUG 2018-11-26 21:43:41,535 (Z-Wave): Command_Builder : Z-Wave command: paramValue = 30
DEBUG 2018-11-26 21:43:41,535 (Z-Wave): Command_Builder : Z-Wave command created successfully
Nathan
