hi
i am trying to get the following Zwave multisensor to work but not having much luck. I have attached the node , boot log and zwave log files. The only time it seems to actually pull any data is whe it associates the first time to the Zwave controller. There after does not seem to update any values. Also if i restart the OR controller, it does not pull any data and all the values show N/A
Z-Wave Plus PIR Multi Sensor, Temperature - Humidity - Light
NFO 2017-04-01 11:11:26,069 : Controller : Z-Wave
node info (ID=15) : [[Device Classes :
‘BASIC_TYPE_ROUTING_SLAVE’,’
GENERIC_TYPE_SENSOR_NOTIFICATION’,‘SPECIFIC_TYPE_NOTIFICATION_SENSOR’],[Capabilities
: ‘NODEINFO_CAPABILITY_ROUTING’],[Security :
‘NODEINFO_SECURITY_OPTIONAL_FUNC_SUPPORT’]].
ERROR 2017-04-01 11:11:26,158 : Command : Failed
to execute [Command : NodeID=‘15’, EndPoint=‘0’,
CommandString=‘BATTERY’, ParamValue=’–’] because could not find a
suitable Z-Wave command class for command ‘BATTERY’.
ERROR [main]: Command : Failed to execute [Command
: NodeID=‘15’, EndPoint=‘0’, CommandString=‘BATTERY’, ParamValue=’–’]
because could not find a suitable Z-Wave command class for command
‘BATTERY’.
ERROR 2017-04-01 11:11:26,183 : Command : Failed
CommandString=‘AIR_TEMPERATURE_SCALE_CELSIUS’, ParamValue=’–’]
‘AIR_TEMPERATURE_SCALE_CELSIUS’.
ERROR 2017-04-01 11:11:26,198 : Command : Failed
CommandString=‘AIR_TEMPERATURE_SCALE_FAHRENHEIT’, ParamValue=’–’]
‘AIR_TEMPERATURE_SCALE_FAHRENHEIT’.
boot.log (55.1 KB)
zwave.log (92.5 KB)
node15.xml (3.03 KB)
