but i always have the last value. May i add a timestamp to create a sequence values about “power” field ? (or another measurement field)
Francesco DG
Which API endpoint are you trying to PUT that data to?
There is currently no HTTP endpoint for uploading historical datapoints for a given attribute; you will have to do this directly on the DB using psql as described in this post:
Historical attribute/sensor data is stored in the asset_datapoint table; the HTTP API for this currently only retrieves data; as mentioned the linked forum post gives details about how to import historical data directly into this table so it is then available for the history charts.
