Deploy openremote on Gcloud VM
Everything working fine on local but when I am deploying the open remote on VM facing some issues:
  • I am able to see the login page
  • After entering username [admin] password [secret] some APIs getting failed.
Request URL: https://31.221.220.169/api/master/console/register
Request Method: POST
Status Code: 403 Forbidden
Error: Origin not allowed
I am pasting my docker-compose.yml file code here for reference.
# OpenRemote v3
version: '2.4'
services:
  proxy:
    restart: always
    depends_on:
      manager:
        condition: service_healthy
    ports:
      - "80:80"
      - "${OR_SSL_PORT:-443}:443"
      - "8883:8883"
  postgresql:
    restart: always
  keycloak:
    restart: always
    depends_on:
      postgresql:
      KEYCLOAK_PASSWORD: ${OR_ADMIN_PASSWORD:-secret}
      KEYCLOAK_FRONTEND_URL: https://${OR_HOSTNAME:-localhost}/auth
      # Use the following if OR_SSL_PORT is not the default 443
      # KEYCLOAK_FRONTEND_URL: https://${OR_HOSTNAME:-localhost}:${OR_SSL_PORT:-443}/auth
  manager:
#    privileged: true
    restart: always
    depends_on:
      keycloak:
      - ./deployment:/deployment
#      - /var/run/dbus:/var/run/dbus
#      - btmesh-data:/btmesh
#   devices:
#     - /dev/ttyACM0:/dev/ttyS0
apart from this, seeing some web socket error in browser console:
WebSocket connection to 'wss://31.221.220.169/websocket/events?Realm=master&Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJ6ajNwOTlySEFUc3RyYXNud2r0PpZRlhzTb0KjKrVagLpmuNqg1EMhTeqvN1EsfmvcsRhpqa46Dbzr3p5soB1Y38ZAY1LmFerlNDlrK_6WoYL_u22lt3XL9Gys-EVk1Ut2-YIlQBz_BDI3-TRt9dGci_CR2faf3_XIasPE8rBrm-7zCsWV8vBQoQkKjSoLjV1uEW7A8sUP8SThOz-ZabQcFh-K22SAMx82jiF30_iFQ2HFxa7_Rs34lelAKug' failed:
You need to specify the OR_HOSTNAME environment variable for the manager service and KEYCLOAK_FRONTEND_URL for the keycloak service.
Also the DOMAINNAME environment variable for the proxy service (if you want automatic SSL certificate generation rather than a self signed SSL certificate).
Please refer to the default docker-compose.yml and/or refer to the deploy.yml which provides some explanation of the different environment variables.
# OpenRemote v3
version: '2.4'
  proxy-data:
  temp-data:
  postgresql-data:
  btmesh-data:
  deployment:
services:
  proxy:
    restart: always
    depends_on:
      manager:
    ports:
      - "80:80"
      - "8883:8883"
      - proxy-data:/deployment
      LE_EMAIL: ${OR_EMAIL_ADMIN:-}
      # USE A CUSTOM PROXY CONFIG - COPY FROM https://github.com/openremote/proxy/blob/main/haproxy.cfg
  postgresql:
    restart: always
      - temp-data:/tmp
  keycloak:
    restart: always
    depends_on:
      postgresql:
      #KEYCLOAK_FRONTEND_URL: https://${OR_HOSTNAME:-localhost}:${OR_SSL_PORT:-443}/auth
  manager:
#    privileged: true
    restart: always
    depends_on:
      keycloak:
      OR_SETUP_TYPE:
      OR_ADMIN_PASSWORD:
      OR_SETUP_RUN_ON_RESTART:
      OR_EMAIL_HOST:
      OR_EMAIL_USER:
      OR_EMAIL_PASSWORD:
      OR_EMAIL_X_HEADERS:
      OR_EMAIL_FROM:
      OR_EMAIL_ADMIN:
      OR_SSL_PORT: ${OR_SSL_PORT:-443}
      OR_FORECAST_SOLAR_API_KEY:
      OR_OPEN_WEATHER_API_APP_ID:
#   devices:
I have updated it but didn’t get any success.
The issue mentioned above has been resolved but now map API returning 204 no content.
Manager container log on local:
org.openremote.manager.map.MapService : Starting map service with tile data: /deployment/map/mapdata.mbtiles
Manger container log on VM[GCP]:
org.openremote.manager.map.MapService : Map meta data could not be loaded, map functionality will not work
@rich should I buy the maptiles for production use?
2022-04-29 15:08:47.048  INFO    [main                          ] org.openremote.manager.map.MapService    : Starting map service with tile data: /deployment/map/mapdata.mbtiles
2022-04-29 15:08:47.136  SEVERE  [main                          ] org.openremote.manager.map.MapService    : Failed to get metadata from mbtiles DB
org.sqlite.SQLiteException: [SQLITE_NOTADB]  File opened that is not a database file (file is not a database)
        at org.sqlite.core.DB.newSQLException(DB.java:1012)
        at org.sqlite.core.DB.newSQLException(DB.java:1024)
        at org.sqlite.core.DB.throwex(DB.java:989)
        at org.sqlite.core.NativeDB.prepare_utf8(Native Method)
        at org.sqlite.core.NativeDB.prepare(NativeDB.java:134)
        at org.sqlite.core.DB.prepare(DB.java:257)
        at org.sqlite.core.CorePreparedStatement.<init>(CorePreparedStatement.java:45)
        at org.sqlite.jdbc3.JDBC3PreparedStatement.<init>(JDBC3PreparedStatement.java:30)
        at org.sqlite.jdbc4.JDBC4PreparedStatement.<init>(JDBC4PreparedStatement.java:25)
        at org.sqlite.jdbc4.JDBC4Connection.prepareStatement(JDBC4Connection.java:35)
        at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:241)
        at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:205)
        at org.openremote.manager.map.MapService.getMetadata(MapService.java:88)
        at org.openremote.manager.map.MapService.start(MapService.java:235)
        at org.openremote.container.Container.start(Container.java:168)
        at org.openremote.container.Container.startBackground(Container.java:209)
        at org.openremote.manager.Main.main(Main.java:31)
2022-04-29 15:08:47.137  WARNING [main                          ] org.openremote.manager.map.MapService    : Map meta data could not be loaded, map functionality will not work
@rich got the solution.
Maptile won’t work if we commit using git lfs.
GitHub blocks pushes that exceed 100 MB.
https://docs.github.com/en/repositories/working-with-files/managing-large-files/about-large-files-on-github
Generally the size of maptiles files we use is around 500-700MB [It’s depends on the area]. For large file we have to use git LFS[Large file storage] and if we use git LFS open remote map won’t work, it give the error File opened that is not a database file (file is not a database) .
We don’t store mbtiles files in repos as they aren’t designed for large binary files. We manage these files outside the docker images as well and volume map them into the manager container.
I got it.
But this should be mentioned in the documentation in the troubleshooting section.
It will save a lot of time for other dev.
We are open source and PRs improving documentation are most welcome.
