is there any idea , how i can fixed it
Hi apurba
Did you configure the SMTP in ̶m̶a̶n̶a̶g̶e̶r̶_̶c̶o̶n̶f̶i̶g̶.̶j̶s̶o̶n̶ docker-compose.yml?
Please show the configuration (without sensitive data ofc)
p.s. I noticed you use Google Workspace, i think you need to use an app-specific password if you havenāt already
Sorry in yml not manager_config.json
This is my configuration, you are missing some ports/protocols
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_SETUP_RUN_ON_RESTART:
OR_EMAIL_HOST: ${OR_EMAIL_HOST:-my.smtp.com}
OR_EMAIL_USER: ${OR_EMAIL_USER:-my@username.com}
OR_EMAIL_PASSWORD: ${OR_EMAIL_PASSWORD:-mypassword}
OR_EMAIL_PORT: ${OR_EMAIL_PORT:-587}
OR_EMAIL_TLS: ${OR_EMAIL_TLS:-STARTTLS}
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM: ${OR_EMAIL_FROM:-my@username.com}
OR_EMAIL_ADMIN: ${OR_EMAIL_ADMIN:-my@username.com}
Did you just change mail configuration or did anything else in the meantime? If you revert the changes it gives the same error?
Did you put both of this?
yes
Hi PCR,
any solution regarding this ,
without port no and Tls , i configured it before and also get email notification .but after changes in yml regarding storage issue ,its not working
I didnāt actually update to the latest version, so itās better if we wait for a comment by someone from the team
Thanks for your support , i tried many options and deploy in new machine also (old yml file)
, Getting same error .
Actually need to show in presentation this feature.
If you guess anything pls share
Tried few more things:
-apparently iām able to make it work only with another smtp, with Google itās not working. Tried a few combinations with/without STARTTLS or SSL but nothing happens. Other SMTP with exact same configuration works
Hi @pcr,
unfortunately I do not get it to work either. Which SMTP did you use? Can you maybe give me some example values to fill in my docker-compose.yml, which you see in the following?
manager:
# privileged: true
restart: always
depends_on:
keycloak:
condition: service_healthy
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_EMAIL_HOST:
OR_EMAIL_USER:
OR_EMAIL_PASSWORD:
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM:
OR_EMAIL_ADMIN:
OR_SSL_PORT: ${OR_SSL_PORT:-}
OR_DB_HOST: ${DATABASE_URL}
OR_DB_PORT: ${DATABASE_PORT}
OR_DB_USER: ${DATABASE_USERNAME}
OR_DB_PASSWORD: ${DATABASE_PASSWORD}
I made it work with this
The smtp is provided by a local national hosting site
If I try with my Google Workspace account, same configuration, it doesnāt work
One thing I noticed, but not sure if itās useful, is that I get the āmust issue STARTTLS commandā if I write the variables like this
OR_EMAIL_USER: my@email.com
Instead if I write it as
OR_EMAIL_USER: ${OR_EMAIL_USER:-my@email.com}
I get the error
Error processing from REALM_RULESET - NOTIFICATION_HANDLER_CONFIG_ERROR (Handler is not valid: email): Notification{name=ānullā, message=org.openremote.model.notification.EmailNotificationMessage@1e26a3b7, repeatFrequency=null, repeatInterval=ānullā, targets=[Target{type=USER, id=xxxx}]}
Iām wondering if heās getting some values from somewhere else that bugs it? From what I understood the parenthesis should mean "use the variable, otherwise by default value is the one following :- "
yeah same thing is happening with me
hi @Don any missing configuration here
Thanks for your answer, but unfortunately it still does not work.
I used:
manager:
# privileged: true
restart: always
depends_on:
keycloak:
OR_SETUP_TYPE:
OR_ADMIN_PASSWORD:
OR_EMAIL_HOST: smtp.web.de
OR_EMAIL_USER: leoxxx@web.de
OR_EMAIL_PASSWORD: xxx
OR_EMAIL_X_HEADERS:
OR_EMAIL_FROM: leoxxx@web.de
OR_EMAIL_ADMIN:
OR_HOSTNAME: ${OR_HOSTNAME:-xxx.de}
and get the following error:
Error processing from REALM_RULESET - NOTIFICATION_HANDLER_CONFIG_ERROR (Handler is not valid: email): Notification{name='null', message=org.openremote.model.notification.EmailNotificationMessage@606ab39a, repeatFrequency=null, repeatInterval='null', targets=[Target{type=USER, id=91d45952-e957-44e0-89b0-d72b3ec71abb}]}
Did I do something wrong?
@Don any idea about this? Have you ever configured an SMTP on Google?
Iāve done something with gmail in a different application and I needed a specific key. Something like this I guess: Sign in with App Passwords - Google Account Help
Edit: Oh, you posted that already. That didnāt work?
Yep, it didnāt work
It was the first thing I thought since Google expect those passwords for anything that doesnāt use OAuth2
I suspect there is something wrong with the combination of ports/protocols, but 587 STARTTLS is the standard for Gmail. Maybe someone else in the staff has an instance with gmail or can give it a try?
