Don’t exactly know how you did the migration,
is it on the same system or on a different one?
Trying to get an idea of where this is coming from…
Were the keycloak and manager instances turned off during the restore process?
Did you specify the correct passwords in the docker-compose files?
Are you using the same version as the server you did the backup on, or have you upgraded?
Don’t exactly know how you did the migration, is it on the sameme system or on a different one?
I have a server running, and I want to migrate data to a new server without interrupting the old server.
Yes, both were stopped before proceeding.
The docker-compose file used is the same (only the domain name is different).
I don’t know, the old server was deployed about a month ago. The docker-compose file used is the same (only the domain name is different). I don’t know if the containers in this new deployment will be upgraded.
