Error with keycloack on vps with docker. Invalid parameter: redirect_uri : SOLVED
Hi All,
I installed Openremote on a VPS with Alpine linux as OS.
I used the docker-compose.yml file as proposed by github.
If the deployment takes place on a local machine (my mac) everything works perfectly, if started on the remote virtual machine docker-compose starts correctly but openremote cannot be accessed from the outside.
The login page shows:
“We are sorry …”
“Invalid parameter: redirect_uri”
I tried to set the remote machine address in the command line:
OR_HOST = vps_ip_address OR_SSL_PORT = 443 docker-compose -p openremote up -d
or
OR_HOST = vps_ip_address docker-compose -p openremote up -d
but nothing to do.
How can I correctly configure docker-compose file?
What environment variables should I add or change?
Thanks for your help.
Cocoa
Try without spaces, i.e. OR_HOST=vps_ip_address docker-compose -p openremote up -d
it keep doing the same.
Seems that the keycloak service has issues if OR_SSL_PORT is the default 443 browsers automatically remove it but then keycloak isn’t happy with the URI…I’ve updated the docker compose files in the openremote repo to exclude OR_SSL_PORT fom KEYCLOAK_FRONTEND_URL environment variable, if you want to run on a different port than 443 then you can uncomment the alternative KEYCLOAK_FRONTEND_URL environment variable.
Hi Rich, issue solved.
Now it’s ok !!
Thank you.
