I am new to OpenRemote. I have setup OpenRemote on windows machine using docker desktop using standard ‘docker-compose.yml’ file. The only thing I modified in the docker-compose file was to expose ‘1883’ port on Manager docker so that I can communicate directly using MQTT (without TLS) bypassing Proxy docker.
Then I followed the steps exactly the way they have been mentioned here:
My MQTT client (MQTTBox) could successfully connect to the MQTT broker (i.e. OpenRemote Manager) but it failed to publish or receive anything on the subscribed topic; rather I could see following warning logs in Manager docker:
2022-06-06 18:52:37.669 WARNING [nioEventLoopGroup-3-3 ] io.moquette.broker.Authorizator : Client does not have read permissions on the topic username: master:mqttuser, messageId: 36761, topic: master/client1/attribute/subscribeAttribute/3FmDQaiZ9ZGR8atbJipiwD
Topic that I am trying to subscribe to is: master/client1/attribute/subscribeAttribute/3FmDQaiZ9ZGR8atbJipiwD
Following are the snapshot for Thing Asset configuration:
I have given FULL access when creating the service user. What am I missing here?
Similar issue occurs when I try to publish [ master/client1/writeattributevalue/writeAttribute/3FmDQaiZ9ZGR8atbJipiwD ] 2022-06-06 19:08:25.667 SEVERE [nioEventLoopGroup-3-3 ] io.moquette.broker.PostOffice : client is not authorized to publish on topic: master/client1/writeattributevalue/writeAttribute/3FmDQaiZ9ZGR8atbJipiwD
I didn’t change the Proxy; instead I added the port (1883) under Manager section of service to actually SKIP TLS so that my MQTT client can directly talk to Manager via 1883. If you want to use TLS, ideally you should keep 8883 (if you are using Proxy).
There does seem to be some sort of coms as when the Subscribe Attribute is unselected in OR we get the following response in mqbx … whatever that means?
When publishing to the writeattributevalue topic then the payload should only contain the value in JSON format, so if your attribute has a value type of integer then your payload would just be:
