After following the instructions User Guide: Custom deployment · openremote/openremote Wiki (github.com), I was able to slightly edit the source code and it worked fine locally. Now how can I deploy them on VMs. I have edited 2 files: \openremote\model\src\main\java\org\openremote\model\security\UserResource.java
AND \openremote\container\src\main\java\org\openremote\container\security\keycloak\KeycloakIdentityProvider.java
As you have edited files in the main openremote repo the custom deployment doesn’t really apply; all you need to do is build your custom manager image:
Thanks for your attention! I just customized the theme a bit, filtering the assets returned from the server. Right now it’s just that. Maybe more customise soon xD
I found the post Container unhealthy _proxy - Custom Deployment - OpenRemote and also tried the fix according to the instructions, but the result is still the same. Can you tell me what I did wrong or what needs to be changed? Thanks for help!
Hi ixxc
Make sure all the 3 lines are there, I had the same issue and fixed it with these lines.
You are looking for:
-line 12 manager-data:
-line 41 - manager-data:/storage
-line 85 - manager-data:/storage
It works when I run it locally. I think the problem is that i ran the update, some old data/configs got conflicted and I’m trying a fresh install from scratch. Thanks for the help!
Differences I found between my yml and yours:
-in postgresql:
I have a volume called - temp-data:/tmp
-Same thing in manager volumes
No idea if it matters, these are the only differences (and ofc replace localhost with your fqdn)
bruh, it’s fine now after clean install. I think the problem is the last proxy service with my domain conflict with the new proxy service . Thanks for helping me!
