Hello there,
I am running into a few challenges that I could really use some help with. I have custom sensors that provide data in a JSON format. I need to figure out the best way to integrate these sensors with OpenRemote. Whats the recommended approach for handling this kind of data within OpenRemote? Should I use a specific data protocol or custom scripting?
Once the sensor data is integrate I need to map it to OpenRemotes control elements; How can I efficiently create and manage these mappings to ensure the data is accurately represented & actionable with in the OpenRemote dashboard?
I want advice on how to handle realtime data updates. What are the best practices for ensuring that the sensor data is updated in real-time or near real time within OpenRemote & there are any specific configurations or settings I should be aware of?
I am facing few issues with data synchronization and occasional errors in data display & What are common pitfalls or debugging tips that you can recommend for troubleshooting these types of problems ![]()
Also i have check this https://forum.openremote.io/t/openremote-white-label-login-page-custom-deployment-help-cybersecurity-interview-ques/1928
Thank you in advance for your assistance & help ![]()
