Hey,
I read in openhab forum that new samsung TV uses a different protocol than older models…
Perhaps is this the problem.
it does not work for me with mine (samsung H5500AW). And the openremote apps crash.
http://www.openremote.org/x/-4YoAQ). I guess this broken link is the same as https://github.com/openremote/Documentation/wiki/Samsung-Smart-TV . However in this latter link the instructions are to change the controller config.properties file with the TV IP address. I guess with the new version 2.6.0 of the controller this is no longer needed and what we really need to do is to go to the designer->config for Controller->samsungtv and insert the TV IP address there. Also, in that latter link it says that the Pro Controller ships with a “dummy” version of the protocol, that prints a warning message. I never get that message but this is probably because I’m not using the Pro version ? I guess I’m using the private version. Anyway, in that same latter link it says to go to my Controller main folder, go to webapps/controller/WEB-INF/lib and replace the existing samsungtv.jar with the one I downloaded above. Actually originally there is no samsungtv.jar file in my controller webapps/controller/WEB-INF/lib folder, so I guess there is something wrong with the instructions or something changed with the new controller version. I placed the samsungtv.jar file in that folder anyway and it didn’t work.
Can anyone help? Is there a way to see what commands the App is sending to the controller and what the controller is sending to the TV? What is the log file for this? I wanted to check if at least the controller is trying to communicate with the TV.
I've not attempted a connection with a Samsung TV yet, but I'll go out on a limb and suggest that this sentence might hold a clue....
"Also, in that latter link it says that the Pro Controller ships with a "dummy" version of the protocol, that prints a warning message. I never get that message but this is probably because I'm not using the Pro version ? I guess I'm using the private version."
Thanks for the prompt reply. I’m new to all this so I guess I’m using the free version of the controller and designer, which is probably the demo version? I just followed the steps at http://www.openremote.com/get-started/ to create a private user account, so I guess I’m using the demo version? How can I know that ?
I’m using port 8688 as recommended by the instructions. I did use the promo code to login so I did not pay anything and I’m using http://designer.openremote.com/ to log in to the designer.
Thanks Michal. I don’t have any folder called samsungtv under logs nor have a samsungtv.log file anywhere so it looks like the Samsung protocol is not active or working. What do you recommend ?
I looked both at boot.log and dev.log and there is nothing related to Samsung there. (I searched for the word Samsung). So the Samsung protocol was not loaded then, how can I load it ?
Yes, I did that, the only thing is that there was no samsungtrv.jar file in webapps/controller/WEB-INF/lib so I just copied the file there. The fact that originally there was no file there doesn’t indicate that there is something wrong with the new controller version ?
Also, please read my previous post which Stuart responded early today to see the steps I did.
Did you or anyone else ever get this to work? I am in the same position. I have installed my controller on a raspberry PI. Added the samsung.jar file to the WEB-INF/lib folder. Connected the and synced my controller to the designer. I can see my remote in the webconsole and on an iPHONE. However, there is nothing in the log related to samsung at all and no response from the TV. So I have had a go at controlling KODI via the HTTP protocol. Added a few buttons, clicked on the and no messages in the HTTP log.
Dev log may hold a clue as it says ERROR [HTTP-Thread-4]: failed to extract panel.xml for panel : No such Panel :NAME, but I think this is spurious as panel.xml says :.
Any ideas where I should look next? Can I change the log levels? Does this even work?
Nobody replied to me and I couldn’t figure it out so I gave up on OpenRemote. One thing to keep in mind is that Samsung changed their IP protocol so the the Samsung.jar file would only work for older TV models. The new protocol is much more complex and I
doubt somebody has made it available for OpenRemote.
